07-01-2015 02:05 PM
@johnsold wrote:
Which disk is the last item on?
Lynn
That is not a NI Supplied component.
In a pinch, if Patience is not found substitue "Foul Language", "Pacing" and "Howling at the Moon." but Patience is recommended
07-01-2015 08:23 PM
While I'm still here recovering my sanity I thought I'd share a quote from an automated e-mail i received from the service request management team.
"Next time, consider posting your question to the NI Discussion Forums for immediate access to engineers and developers around the world. NI Applications Engineers monitor the forums to ensure all support questions are answered. To access the discussion forums, please visit http://forums.ni.com."
To be honest, I had linked this thread to the SR while I filed the SR! I guess i'm "Ahead of the times"
07-02-2015 09:14 AM
Did the email have your picture, too?
Lynn
06-26-2018 02:16 PM
I have this same problem, but the solution that worked for you no longer works because everything has changed since then and there is no option to install or repair LabVIEW Run-Time Engine 7.1.1
I've contact NI phone support, but 3 weeks have gone by and all I get is an email saying that they will escalate this.
06-28-2018 05:38 PM
Can you give more information?
Why cant you reinstall it?
06-29-2018 06:31 AM
I read that it won't run on Windows 7. I tried to install it anyway, but I get a popup saying a higher version is already installed. I uninstalled everything from NI, but still get the message.
07-02-2018 10:23 AM
Hi Fewoiz,
LabVIEW Run-time Engine 7.1.1 is not supported on Windows 7. The earliest version of LabVIEW, and thus LabVIEW Run-Time is version 2009. Therefore, National Instruments cannot guarantee or predict the behavior of our downloaded software on an unsupported OS.
Otherwise, a computer can have multiple versions of LabVIEW and LabVIEW RunTime without them interfering. I suggest either using supported software for Windows 7 or downgrade the OS to something that is compatible.
Parul
07-02-2018 02:47 PM
I don't know why I'm getting this pop up error every time I open LabVIEW 2015. I click cancel 3 times and then LabVIEW opens. Well, at least it used to, now I can't even get LabVIEW to open after uninstalling and reinstalling all NI products.
Why would it ask for NI LabVIEW Run-Time Engine 7.1.1 if it's not even supported?
07-02-2018 03:35 PM - edited 07-02-2018 03:35 PM
LabVIEW and LabVIEW Run-Time need to be the same version. If the .exe you are using was built in LabVIEW 7.1 then it might prompt you to have that downloaded.
Please attach a screenshot of the error you are receiving. Also, try repairing and/or force reinstalling LabVIEW 2015.
Parul
07-03-2018 05:56 AM
The only executable I'm trying to run is LabVIEW 2015. I did a uninstall and a reinstall, using the command prompt: setup.exe \reinstall.
I will add a screenshot of my error messages as soon as I get back over to that work station.
