Insert symbol into word doc using report generation tool kit
I am trying to insert a tick mark or a corss mark into the word doc by reading the bookmark. To input any value, I was using a string control. But,I was unable to input these symbols. I tried doing by inserting an image, but it is inserting the image but not replacing the bookmark. Please help me with this!!
Message 1 of 11
(5,455 Views)
Maybe these symbols are not included in the character set used by Word. Do you get something else or nothing, is there an error message?
Ben64
Message 2 of 11
(5,405 Views)
Is that the paragraph symbol that you want to insert?  If so, this should work for you.
aputman
Message 3 of 11
(5,396 Views)
Accepted by bineesh142
Ben64
Here is an example of what I said:
To insert the checkmark I need to set the report font to Wingdings (change back the font to default after). If I don't do this the ü character will be written (character 0252 of the default font).
Ben64
Message 4 of 11
(5,388 Views)
I want to pass a tick mark & a cross mark.
Message 5 of 11
(5,363 Views)
There is no error msg. It is writing into word but I open the doc its just a small box which displays.
Message 6 of 11
(5,362 Views)
I'm not sure what a tick mark and a cross mark are specifically.  But you can change the font on the InsertSymbol method and use the character number for selection.  This is much easier than changing the font, pasting a character into a string, and then changing the font back to default.  253 and 254 from Wingdings is
aputman
Message 7 of 11
(5,329 Views)
Sir, Can you attach this as a vi, I cannot find items in labview as I dont know the labels.
Message 8 of 11
(3,733 Views)
But in the word report generated I still get symbol like "u" with two dots on top, and not check marks. Please help me in getting check marks in word report.
Message 9 of 11
(3,726 Views)
The picture I posted is a snippet.  The LabVIEW code is embedded in the PNG file.  Drag the picture to your desktop and then drag it onto a block diagram and the code will be added.
aputman
Message 10 of 11
(3,714 Views)
