10-01-2008 04:32 AM
is there anyone know how to insert a picture from a front panel indicator into a excel sheet, I tried Addpicture (ActiveX) method, but it needs the filename of the picture, how can I get this filename of this indicator.
thanks a lot
10-01-2008 06:19 AM
10-01-2008 08:56 AM
Patience... patience...
What kind of indicator? Is this a graph indicator, or a numeric indicator? I'm not familiar with the AddPicture method, but if it's looking for a filename then you need to save the image to disk. For a graph indicator you can get the graph image using an Invoke node and then use the picture functions to save the image to disk.
10-01-2008 09:12 AM
is that possible to save picture in to excel directly without saving it to some certain place in dick firstly, then get it back to labview. like in this picture.
10-01-2008 09:22 AM
Please don't upload bitmaps by changing the extension. Changing the extension of a file does not change the file type. Your bitmap saved as a PNG goes from 906KB to 19KB. That's 4700% smaller! Even MS Paint will allow you to save as PNG. Sorry for the rant, but that's a pet peeve around here. Nobody is picking on you.
As for your question: The documentation for that method indicates it requires a filename. That's how the method works, so you have to save the image to disk.
10-01-2008 09:32 AM
