01-13-2014 04:55 PM
I need some help determining how to initialize a test cycle after vi execution has begun. I have four set points that need to be reached (at 25C, 235C, 275C, and 325C) yet the test cycle may start after the run button has been pressed. For example, I need to ramp up the temperature for a transducer from ambient 25C to 235C (over an hour), soak for an hour, then ramp from 235C to 275 (over an hour), soak for an hour, lastly - ramp from 275C to 325C (over an hour) then soak for an hour. How could I achieve this say - three minutes after the run button has been pressed? Any help will be appreciated. thx,
01-14-2014 02:36 AM - edited 01-14-2014 02:38 AM
Hi Newton,
you should consider a state machine approach. You really should...
Possible states: wait, ramp, soak…
What's the purpose of the attached pictures?
Waht's the purpose of the "1 iteration"-FOR-loop? If it only iterates once you don't need a loop...
