Initialize cluster with different datatypes (a lot of data)
Hi
I have data, which consist of different datatypes. First i have initialize cluster with those datatypes and then "printed" it to indicator (picture). In picture case data is carrying 8 chars ja 4 floats. That was easy to intialize, but here comes the question: How i can do this same if i have data which look like this (examble):
float value
char name [32]
Short value [16]
Do i have to create loooong cluster which have one float, 32 chars, 16 shorts? Or can i create those "tables" in some other way?
Thx again 🙂
-Aa-
(2,719 Views)
Accepted by topic author Alias A
I'd suggest using array-to-cluster and configuring the cluster size to match the size of your arrays, then bundle those clusters together.  In terms of LabVIEW's storage, there's no difference between a cluster of
float value
char name1
char name2
short value1
short value2
and a cluster of
float value
-> embedded cluster of
     char name1
     char name2
     short value1
     short value2
So you can use array-to-cluster to get the right sizes instead of creating all those values individually in one giant cluster.
(2,704 Views)
