Hi Don !
My first guess of a 6D problem was false, that's simply a 5D problem !
I have been confused with the name you gave to the axis, since X and Y (sometimes x and y) were also T and I..., until I went through your previous posts and found that you were interest in image analysis.
From what I have seen with your data, you will not end with a surface, but with a messy volume, kind of thick triangular piece : each individual triangle overlay/intersect more or less the previous one, with a variation in position and slope.
The code attached in my previous post is pure W2K stuff, compressed on my PC. Here is a zip wersion, compressed on my Mac ! Again in two chunks...
There, I draw ONLY one triangle at a time, a
nd the corresponding pixel (index) can be choosen on the 2D image. If you modify the axis of the 3D picture, to fix them ("don't autoscale"), you will see when moving the cusor that there is no clear pattern of evolution of the surface.
So either some measurement noise is hiding the surface you are looking for, or it's not there !
CC
Chilly Charly (aka CC)
E-List Master - Kudos glutton - Press the yellow button on the left...
