Increments for for loops
HI,
I am attempting to do a for loop similiar to the following c text ( for i=32, i+2)
Please tell me if it is possible to increment in Labview by more then 1 in a for loop and secondly if I can start the loop at another number except for 0
Thank you
Message 1 of 11
(3,611 Views)
You can multiply [i] by two and you can also add a constant to the result. That should be sufficient, right?
Message 2 of 11
(3,607 Views)
Nope.  Loops start at 0 and increment by 1
Of course you can use "i*2" and N=17 to generate the series 0,2,4,6,8...,32
"Should be" isn't "Is" -Jay
Message 3 of 11
(3,606 Views)
You can also create your ramp using e.g. "ramp pattern" and autoindex the result into the FOR loop.
Message 4 of 11
(3,601 Views)
As far as i tried I can not update I - I tried i +2 but that is good for the graph and not for the loop. I did not manage to to start i on 32
Message 5 of 11
(3,597 Views)
You can not modify i. It tells how many times the loop has iterated and that is it. You can wire 32/2 to the N terminal.
LabVIEW 2012
Message 6 of 11
(3,589 Views)
Thanks I will try but I still am interested to know if there is a way to start I on any number and increment by more then 1
Message 7 of 11
(3,587 Views)
There are plenty of ideas out there to add this functionality in the future. (example)
Message 8 of 11
(3,581 Views)
Thank you, I guess I will just have to work my way around this case, I have some ideas but i was trying to shorten it to one for loop
Message 9 of 11
(3,575 Views)
Accepted by topic author Oferer
I usually do something similar to the following.
Message 10 of 11
(3,571 Views)
