Incremental Encoder (Megatron SPNT Series) and NI USB-6009
Hello everyone,
just came across the forum. I have questions about NI USB 6009 and a rotary incemrental encoder. I am currently using the NI USB 6009 and the Megatron Incremental Encoder SPNT series for my project. My arrangement is as follows:
Channel A and B from the encoder are connected to port1/line0 and port1/line1 respectively.
I am using the 5V and connected to the Ground as well (standard wiring).
My question is how can I plot the the square waveform signal? I need that information so I can calculate the angular velocity.
I really appreciate your help
(937 Views)
The USB 6009 is a low cost device. It does provide timed acquisition on the analog inputs but none on the digital inputs. This means that in order to acquire a meaningful waveform for your two digital signals, you will actually have to connect them to the analog inputs and setup a timed analog acquisition for them. You can then do your analysis on the analog measurements or convert the analog values into a digital waveform if you absolutely want to.
Rolf Kalbermatter  My Blog
(932 Views)
