07-27-2018 01:18 PM
I want to programmatically increase the size of the image generated by this code:
Does anyone know of a way to accomplish this? Thanks.
07-27-2018 02:33 PM
If you make the TypeDef a non-strict TypeDef, you can change the PlotSize property as you wish.
07-27-2018 02:34 PM
If you just want to increase it by a factor that's an integer, you can use array interleaving & building.
07-27-2018 07:28 PM
The picture is a pixel-by-pixel representation of the front panel graph, so if you want more resolution you could e.g. create a subVI with a much larger, but otherwise similar graph, call it on demand and get it's picture instead.
