07-31-2020 02:00 PM
Hi Marcus,
Sorry for being so long to reply.
Thank you for your great job.
In order to consolidate a complete source code, would be possible that you also post the C project in the same way jjjcjj did before ?
Sébastien
08-02-2020 06:37 AM
Hi jjjcjj,
Do you remember what you did exactly for these two points :
- does correctly have timeouts
- has much much better performance (i was forgetting to set the winpcap buffer size... oops) : seems default buffer size is OK... Or maybe you thought about the registry key you mentioned earlier ?
08-17-2020 03:45 AM
Here it is:
08-18-2020 04:03 AM
That's perfect, thank you
08-19-2020 10:55 AM
I can't see the project because I don't have LV 2019 installed, but if it's the example I'm thinking of, be aware that it is intended to be used as a standalone application and doesn't output any errors.
08-20-2020 02:05 AM - edited 08-20-2020 02:07 AM
Hi!
On the LabView page I did not modify that much, but of course I don't give any warranty on anything 😉
BR
Marcus
08-20-2020 12:08 PM
@marcuskr wrote:
Hi!
BR
Marcus
Don't get me wrong. I'm not saying it's bad programming at all. I'm just saying it doesn't expect to get called, so it doesn't report any errors. It may give you a visual indication, which is fine for a standalone, that's all I'm saying. 🙂
