In the Numeric Edit Box, how can I set the number appearing on the right side?
I tried to use its property node, the position only can set on "the Top" or on "the Left"? I know this is easy one, but it will save my time to search for the solution! Any one can help?
(2,269 Views)
I assume you want to change the justification of the number within a numeric control or indicator to be on the left, in the center, or on the right within the display. I don't know of a way to do this programmatically, but you can do it from the front panel by clicking in the control with your text tool, going up to the font menu ring on the toolbar, selecting "Justify", and choosing "Right". You can find out more information about manipulating front panel objects in the LabVIEW Help.
If this doesn't answer your question, let me know, and please be more specific in your description.
Darren
(2,269 Views)
Hi Darren
Thank you for your answer, it is OK now!
Thanks a lot
(2,269 Views)
