01-30-2008 07:48 AM
01-30-2008 08:40 AM
01-24-2012 02:54 AM
Your answer is incorrect. In LabVIEW Help, Analog Input:Maximum Value Property(AI.Max) is "Specifies the maximum value you expect to measure. This value is in the units you specify with a units property. When you query this property, it returns the coerced maximum value that the device can measure with the current settings". Try my tiny program.
I think that all settings shown in task pane of NI-MAX must be readable with DAQmx channel property node.
01-25-2012 02:37 AM
Is this a bug? An Output value of AI.Max is different to an input value of the AI.Max. Select a physical channel and run my new test program.
01-25-2012 12:34 PM
Your example seems to prove that my answer was correct. What is returned is the coerced values - just what I said would happen.
And no, this is not a bug. It is intended behavior. It is simpler to just specify an input range in terms of the expected signel instead of checking to see what are the actual ranges supported by the DAQ device. If the actual range matters in terms of learning the actual resolution for example, then you do the read.
01-25-2012 10:41 PM
Thank you. I want to get all values shown in NI-MAX. I guess that more members of property is necessary such as AI.ActualMax.
Try my next program. This is the reason why I found out this page. Why error occur in a DAQmx Channel Property node?
If an indicator "AI.Max 2" is removed or a boolean "Don't use AI.Max" is turned to true then no error occur.
Error occur with Lv2011+DAQmx9.4 or Lv8.6.1+DAQmx9.3, but no error with Lv7.1.1+DAQmx7.5.
