From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
In LabVIEW, how can I access the channels of my 40 channel single-ended multiplexer?
I need to access channels in order to increment them while I am using an external multimater to measure each channel.
Message 1 of 8
(3,428 Views)
I think a little more information is needed. Like what kind of multiplexer...
Message 2 of 8
(3,428 Views)
If this is related to your earlier post about the HP34970, I think I might understand now what your problem is. The instrument library assumes that you are using the internal DMM. None of the other VIs have a numeric input for channl. I've attached a VI that should allow you to specify slot and channel #. Follow this VI with the one for taking a reading from the DMM.
Message 3 of 8
(3,428 Views)
I have a similar question...except I am using a 20-channel mux (HP34901A without the internal DMM) instead of the 40 channel one. I looked through the code and it seems like there should not be any difference in scanning, i.e.I should also be able to use the channel_select.vi provided earlier without having to modify, but I want to confirm.
FYI, The difference between the 40- and 20- channel mux is the 40 channel is single ended and in the 20 channel one each channel has a HI and LO (differential)
Also, I have connected the COM on this 34901A module to an external DMM, so do I need to add any another VIs or can I just use the channel_select.vi as long as I initialize the 34970A instrument, etc? (and then write to file to save the data)
Message 4 of 8
(3,202 Views)
I am using Labview 7.1 and have downloaded the HP34970A drivers associated with the H34901A mux module.
Message 5 of 8
(3,197 Views)
Sorry for the multiple posts.
Dennis I just saw that in August 2006 you had posted something that answered this question. Let me try what you showed and repost if I have further questions.
However, feel free to add any other suggestions you may have...
Thanks!
Message 6 of 8
(3,193 Views)
labviewhokie,
Could you post a link to the Forum you found the answer in to help future people with the same issue? Thanks
-Marshall R
Message 7 of 8
(3,167 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=203411&query.id=42039#M203411
You can find it by typing "34901a" in the search box
Message 8 of 8
(3,163 Views)
