Kevin B. Kent wrote in message
news:38FDD2D9.CF0DA8DF@usa.alcatel.com...
> Magnus Holmgren wrote:
> > I have a application that must always work with a maximum time delay of
> > 100ms.
> > It works fine mostly but not as stable as I would like.
> > I have defined the process 'Time Critical'.
As well as changing the priority of the VI within Labview, you also have to
change the priority of Labview within the system- go to task manager, click
the "Processes" tab, find "labview.exe" and popup the right mouse button
menu over it. Under "set priority" you'll see "realtime" at the top of the
list.
Be warned though that setting a task to "realtime" means that task has
priority over most others and if your program cocks up, you're li
kely to be
locked out of NT and have to reboot. So save everything first 😉
