Importing items from a text file to enum
I have a text file with multiple items in it. I don't want to write each and every item in the enum manually. Is there any easy or shorter way of writing/importing these items directly into an enum ?
Thanks in advance. ☺️
Message 1 of 11
(2,199 Views)
Are you looking at defining an enum at edit-time or run-time?
If at run-time, you should be using a Ring.  You can set the values for a ring using a property node with the Strings[] or the Strings and Values[] property.
If at edit-time, then you can do something similar, but you will need to use "scripting", which would require getting a reference to the enum from another VI in order to update the values.
GCentral
Message 2 of 11
(2,190 Views)
I think the major roadblock is that you cannot edit strings and values of an enum while the VI is running.  But you can get around this.  You could create the enum in VI #1, create the code to auto-populate your enum in VI #2, working with a reference from the control in VI #1.  That way, VI #1 isn't really running, so you can modify the properties.  I've done it before, so it's more than just a theory.  It's not my idea - I saw it here somewhere...
Edit:
I forgot an easier way is to auto-populate a ring, then replace it with an enum.
Bill
CLD
(Mid-Level minion.)
Message 3 of 11
(2,156 Views)
@billko please elaborate on how to auto-populate a ring.
Message 4 of 11
(1,573 Views)
Basically you make a VI with a ring control in it and you create code to load the text into your ring via property node "Strings".  Once you've done that, you should be able to replace it with an enum.  I think there's a "fancier" way of doing it that involves a reference to an enum in a non-running VI so you can skirt the "can't modify an enum at runtime" issue, but this was easier to do.
Bill
CLD
(Mid-Level minion.)
Message 5 of 11
(1,557 Views)
please use the ArrayToEnum tools.
Message 6 of 11
(1,542 Views)
@ronke Where do I get the ArrayToEnum tools?
Message 7 of 11
(1,521 Views)
The key is to set the Enum strings when the .ctl is not reserved for running:
Paolo
Message 8 of 11
(1,504 Views)
please refer attached toolkits.
Message 9 of 11
(1,498 Views)
Oh, arraytoenum_v11.zip from https://lavag.org/files/file/61-variant-to-control/. Or simply with a file containing each word on a line, create a new Ring and this Read from Text File to Spreadsheet To String Array code, run it, then Right-click the front panel Ring, Replace, Enum.
Message 10 of 11
(1,491 Views)
