Importing items from a text file to enum
I have a text file with multiple items in it. I don't want to write each and every item in the enum manually. Is there any easy or shorter way of writing/importing these items directly into an enum ?
Thanks in advance. ☺️
(333 Views)
Are you looking at defining an enum at edit-time or run-time?
If at run-time, you should be using a Ring.  You can set the values for a ring using a property node with the Strings[] or the Strings and Values[] property.
If at edit-time, then you can do something similar, but you will need to use "scripting", which would require getting a reference to the enum from another VI in order to update the values.
GCentral
(324 Views)
I think the major roadblock is that you cannot edit strings and values of an enum while the VI is running.  But you can get around this.  You could create the enum in VI #1, create the code to auto-populate your enum in VI #2, working with a reference from the control in VI #1.  That way, VI #1 isn't really running, so you can modify the properties.  I've done it before, so it's more than just a theory.  It's not my idea - I saw it here somewhere...
Edit:
I forgot an easier way is to auto-populate a ring, then replace it with an enum.
Bill
CLD
(Mid-Level minion.)
(290 Views)
