Import Text File To Interpolated 3D Surface
Accepted by topic author Linty_C
If you want to have the axes shows as 0..100, just create x and y ramps with N (i.e. size of dimension!) elements going from 0 to 100.
Message 11 of 13
(1,011 Views)
Great - Thank you @Altenbach! In case anyone is curious, here is a sample what real world data looks like on a log-scale.
Message 12 of 13
(968 Views)
I am glad you got it working.
(There were definitely some head-scratchers in your original code, for example basing the x and y axes on the Zmin and Zmax of a particular row or column instead of the array indices. 😄 )
Message 13 of 13
(960 Views)
