Implementation of linear fit between two cursors
Problem solved Thank you.
With Regards
Phani kiran
Message 11 of 19
(2,334 Views)
Have a look at this old solution instead for some additional ideas. 😄
Message 12 of 19
(2,331 Views)
Wow, great idea.
Thanks a lot altenbach. Helped me a lot.
With Regards
Phani kiran
Message 13 of 19
(2,327 Views)
Hi man i really need your help!!
I need to interpolate all the points in a xy graph between the two cursors selected...is it possible?
Thanks 🙂
Message 14 of 19
(2,281 Views)
Of course it's possible as the published code here shows. Have you looked at it and tried anything? What is your specific problem?
Message 15 of 19
(2,278 Views)
Thanks 🙂
This thread is about fitting, not interpolation, and it is already marked as solved.
Please start a new thread with your new problem. Please also explain what you mean by "interpolation", maybe attach a picture.
Message 16 of 19
(2,267 Views)
Ok i'll do that,i was only asking if you could explain me how to extract all the data in a XY Graph from the cursor A to the cursor B 🙂
Message 17 of 19
(2,233 Views)
No, that was not what you were asking.
If you look at the code discussed above it shows how to do this. Use a cursor that is locked to the plot and then read the "cursor index" property of each. Take the subset from the lower index with a lenght of the difference between the two indices (do a +1 if you like).
Message 18 of 19
(2,227 Views)
Message 19 of 19
(2,225 Views)
