02-12-2016 02:48 AM
you have to take the "Basic" Constructor and the method "Initialize_MyDevice" with the parameters USBIndex = 0 and ProductID = 0xA04.
With this settings you have access to the LIN serial analyzer (APGDT001) in LabView.
Try it and give me feedback if it works.
You're welcome!
02-12-2016 09:04 AM
This sentence returns false:
Dim PID As UShort = &HA04
If (PICkitS.Basic.Initialize_MyDevice(0, PID)) Then
But Network analyzer tool can detect the hw...
10-12-2017 09:51 AM
Hello joisef,
I want to read a lin message from APG Lin Serial Analyzer.
You wrote after "initiaize_mydevice" you can set the baudrate for lin.
But in BasicConstructor I can't find a function for setting the baudrate.
Should I instead use the "LIN" constructor with "change_lin_baud_rate" function?
Or which function did you use?
Do you know wich funktion I need to read a lin message which was send to APG Lin Serial Analyzer?
Kind regards
Tanja
10-13-2017 01:46 AM
Hello Tanja,
this project is long time ago. So I have this misremember. Although I have search in old files and i have found this cutout.
For receive a message you can try OnReceive or OnAnswer. Recommendable is also the documentation PICkit Serial DLL (PICkitS.dll) Function Prototypes.
Good luck and wish you the best.
Tobias
12-23-2021 03:26 AM
Please I'm trying to control a PICKIT 4 device using Labview and I use the pickits.dll but it does't work. I wanted to nkow if it's possible and if yes how?
Best regard.
03-08-2022 11:25 AM
hello, i have a problem, or i don't know for sure what to do, i have a serial analyzer and a resistive touch screen that i want to connect to labview but i can't see them or i don't know from where to connect, you think you can help me with my problem?
05-08-2022 03:33 PM
hello, i have a problem implementing a pickit dll, do you think you can help me?
