08-30-2019 06:24 AM
Hello Labviewers.
Actually I'm developing in sbRIO FPGA, and in my application I have to use a butterworth filter after a data acquisition and after that I have to implement a dot product.
The idea is to fill in an array, DMA with a certain number of filtered data.Once the array is filled i will proceed to make the dot product.
But I found that I cannot perform a butterworth filter and a dot product under the same loops, because, the filter node work in a while loop and the dot product only work under a while timed loop.
Should I do this in two differents VI that call each other when they finished or it is better do in the same VI? How can I do this, is there any module to call different VIs that works on FPGA?
09-05-2019 04:39 AM
@GuilleCad wrote:
Hello Labviewers.
Review any examples related to your project. For example. there is a cross correlation example (uses FlexRIO) that is similar to dot product on FPGA, see that first.
Data on the FPGA should be streamed a few samples at a time. You should not fill up an array and then filter/process. This is 'software' thinking. On the FPGA, you have to think in terms of streaming data. Also allows for streaming and higher throughput.
You can use a Target Scoped FIFO to get data from one loop to the next.
On the FPGA you can have only one top-level VI running at a time so it has to be from one VI (they could be subVIs) but that may be too early for now.
09-13-2019 07:10 AM
Thanks for the reply.
I implemented your solution of using an target scoped FIFO and put a Dot product into a time loop structure and it works.
es
Also i put the FFY module inside this loop and it works well, until it finish their calculation that it appears it does not reset the module to start a new calculation.
Any suggestion?
