I understand that I should copy the new lvrt.msi file onto MY machine. There are a few other machines, which have the Run Time Engine only, that run my exe's. Do those machines need to be fiddled with?
You should have the same version of runtime engine as your Labview. That means to run an application that was built in 6.0.2 you would have to have 6.0.2 runtime engine. Hope this helps.
