Identify if the subvi is called for the first time by a second top-level VI
I need to execute a section of the code only when a particular subvi is called for the first time by a second top-level caller. Now the obvious problem with using the 'first call?' function is that identifies the first call since the start of the top-level VI.
Is there a way to identify the first calls since the start of the second top-level vi. As my second top-level vi has to open and close multiple times
Message 1 of 21
(2,358 Views)
Use Some Variable (Boolean) By Default Let it be True  which executes Sub VI For the First time after which make the Boolean False and For Next time you bypass the Case by using Boolean Variable.
Message 2 of 21
(2,333 Views)
I wanted to do that for multiple VIs, therefore was looking for subvi routine that is equivalent to "first call?" function but it returns true whenever the second top-level VI call a particular subvi for the first time.
Message 3 of 21
(2,312 Views)
Put the first call primitive into the top level VI and pass it into the subVI through the connector panel.
Message 4 of 21
(2,299 Views)
Sorry I didn't understand that.
To reiterate my requirement
- I have a top-level VI 'A', which calls a second top-level VI 'B'.
- B further calls 'C', 'D' and 'E'.
- If I use a first call function in C, D, E, it would return true in the respective only once until A is running no matter how many times B opens and closes.
- What I need was that every time B closes and opens again and calls C, D, E for the first time I need a flag that sets high.
Message 5 of 21
(2,284 Views)
Don't put the first call in the subVI's.
Put a boolean control in those subVI's that shows up on the connector panel.
Put the first call in the top level VI and pass that into the subV's through the connector panels.
What you've described in this message seems to be a little bit more complicated than the original message.  You only described one level of subVI's before.  Now you are describing two levels.  But the principle is the same.  Let the higher level VI's tell the subVI's when they are being called for the first time.
Message 6 of 21
(2,274 Views)
  • How does A call B?
  • What else calls C, D or E? (except B)
  • Does B call these VIs (C,D,E) multiple times? Is that why you want to know which is the "first" repeated call?
GCentral
Message 7 of 21
(2,258 Views)
A calls B multiple times and I control with a boolean logic when the calling of B should happen
C, D and E are only called by B
Yes B calls C D E multiple times before it closes. And yes that is why i wanted to know which is the first repeated call, i.e (first call) for time the B is called by A
Message 8 of 21
(2,255 Views)
If I make a small demonstration code and post here would you please help me implement this modification you suggested. Maybe I am still not being able to convey what I wanted properly or failing to see how your suggestion suits what I require
Message 9 of 21
(2,252 Views)
Then the logic described by RavensFan will work perfectly here: during the execution of B, you know which is the first call of each of C, D and E.
You can add a boolean to the connector pane of those 3 VIs, and specify their value in B's block diagram.
Here you see a dummy example that calls D twice (true the first time, false after) and C repeatedly (true the first time, false after).
Of course, this doesn't run, but hopefully it demonstrates the idea.
GCentral
Message 10 of 21
(2,248 Views)
