IT'S BROKEN. no, it isn't. YES IT IS. no, it isn't. YES IT IS. no, it isn't.
LV2013 SP1
The arrow is broken, and there's nothing wrong. Not wven a warning.
This post says to try CTL-click or CTL-SHIFT click on the RUN arrow - they didn't help.
Closing the VI tells me it needs to save 594 items (I backed up recently, so not to worry).
Re-opening the VI didn't change anything.
I quit LABVIEW and restarted - it's still broken, but now it complains about a wire with loose ends.
But the only reason it has loose ends is because it deleted two property nodes that were connected there.
Worse, it re-connected one property node to a different control !
Let's hope it was only one...
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,235 Views)
TRY, open you code that is giving you touble, go to block diagram, CTRL-A to select all and copy all, and paste into a new VI.  Somehow magically fixes strange issue.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,185 Views)
Oh LabVIEW you silly thing you!
Smiley Frustrated
(3,154 Views)
