08-27-2019 06:05 AM
08-27-2019 07:19 AM
Hi Tfrl,
Is it possible to control the flow rate via LabVIEW of the above mentioned pump? If so, how?
I guess you read the programming manual for your pump. And/or have asked the manufacturer for support!?
What is the result of those tasks?
08-27-2019 07:39 AM
Thanks for your quick reply.
I've tried to contact the manufacturer but no reply so far.
The manual doesn't explain anything. It seems it's possible to control the flow rates but I'm not sure, that's why I'm asking it here.
My intention is to control the pump (turn on and off, set the flow rate and the direction) via LabVIEW.
08-27-2019 07:45 AM
Hi Tfrl,
All this is possible - when/as long as that pump allows to set all those parameters! Does it provide commands for flow rate adjustment?
Apparently you can switch on/off the pump: are there also commands to set/get flow rate?
That's why I asked for the programming manual…
