04-20-2006 11:31 AM
04-20-2006 12:12 PM
You can select any port between 1 and 65535 as long as it isn't used by another program, but you should know that some of these ports are reserved. Ports 1-1024 are usually reserved for the system and other programs use other ports.
If you only have a single communication channel you should be able to use the default port with no problem. If you want to make sure that you will not have problems with other LV code you can assign your own ports, as long as they're not used by other programs.
04-20-2006 09:28 PM
