07-20-2013 11:42 AM - edited 07-20-2013 11:56 AM
Hello everyone,
i plan to make a guidance system for the visually impaired.
for this i wish to acquire the image from a mobile phone working on Android ICS through an app called IP WEBCAM . Further , i found an article on ni.com which assists users to interface IP WEBCAM to any NI software. unfortunately i am not able to execute the final step of the execution ie. i cant understand which application to restart? i have tried restarting the webcam , adapter with little success.
i am enclosing the link of the article for your kind reference:
http://digital.ni.com/public.nsf/allkb/3D9CEA3E7B26FA4586257A56004E4507
is there an alternative software for the ip webcam adapter which i can use ?
Even while operating the VISION ACQUISITION EXPRESS VI from the VISION AND MOTION PALETTE when i am not able to detect either the integrated webcam of the laptop or the IP WEBCAM that i intend to use in the project but i can acquire images from the integrated webcam using the NI VISION ASSISTANT. I have even enclosed a pic to highlight the problem i face regarding the interface between the camera and labVIEW.
shall sincerely appreciate all possible help
regards
SHAGGY
07-20-2013 02:28 PM
Clicking on any of the two links you provided, takes me to rediff.com...!!
Well, you should check in MAX, if you've installed IMAQ drivers.
Also in my laptop, I can see atleast Laptop's webcam listed in MAX.
After doing settings, even MJPEG cam added to the available camera list (in MAX).
however not able to connect to the Android camera.
07-21-2013 03:17 AM
hi,
thanks for your prompt response
i had downloaded an NI package which said that it had imaq dx driver but the same is not reflecting in my NI MAX. so will have to install it again.thanks indeed.
did you read the article about IPWEBCAM linking with labview?
01-20-2014 09:16 AM
Although there are other methods of interfacing with IP Cameras, one very simple method is to leverage Virtual Webcam software which emulates the functionality of a USB webcam. One such piece of software is the IP Camera Adapter. Once this software is installed, it will be capable of emulating your MJPEG stream as a DirectShow device. This will allow the IMAQdx drivers to use the camera and, therefore, allow you to interface the camera with LabVIEW and NI Vision. You can review the information:
http://digital.ni.com/public.nsf/allkb/9446A8C25CC99F7586257A56004D513D
01-31-2017 04:39 AM
if android phone can't response to MAX what tye of phone did you use?
