10-27-2017 02:38 PM
Hi all,
I have made sure to activate IMAQdx. The license manager and MAX both confirm that it was installed.
However, I can't see any of the IMAQdx in my palette, although the existing IMAQdx subVIs in my diagram were successfully found and executing properly.
Do I need to manually show the palette where IMAQdx is installed locally?
Thanks!
10-27-2017 03:34 PM
You probably need to configure the Block Diagram "gadget" to show Vision and Motion VIs (by default, only a particular subset of VIs, presumably those NI thinks are the best "default" choice) are visible. To "adjust" this:
