IMAQdx error unable to set attribute
I'm using the property node to control attributes of my point gray camera. Each time I open a new VI session I get an error: unable to set camera attributes.
my code can't set the attributes when i re-open a session.
I attached an image of my code.
(2,814 Views)
Can you post the code itself instead of an image ? The image does not show all your code and does not display the name of the VIs you use.
Yddet
(2,784 Views)
When you attach your code, you should attach enough of it that those of us who have Point Grey cameras can try your code with our cameras.  As this may require multiple VIs (maybe even an entire LabVIEW Project), gather the VIs in a Folder, compress the Folder, and attach the resulting .zip file.  We'll be able to better understand what you are doing and to test it, ourselves, vastly improving the chances we can say something helpful for you.
(2,776 Views)
this is the code
(2,720 Views)
