04-20-2009 06:05 PM - edited 04-20-2009 06:08 PM
Some IMAQ Vision functions malfunction if you use the source image as the mask. I keep running into this bug in IMAQ Vision, some Vision functions exhibit this behavior, and some don't. It is not documented in the function descriptions. Even if it were, it would still be a bug. Example:
1. Create a U8 source image that contains some zeros and some nonzero values.
2. Wire the image into the source input and mask input of IMAQ Quantify and return the % value of the global report to see what percentage of pixels are nonzero.
The answer is wrong. If you copy the image into a separate image first, and wire the separate image into the mask input, you get the correct answer. See attached VI for edification
Cheers,
-root
04-21-2009 09:35 AM
