Timing with my equipment is not critical ... measured 160ms or so... with
the original limit..( close to 400x400 )
I can live with more than a second...
So I thought, that there is a workauround on the limit...would make life
sometimes easier 🙂
Shure found a way which works, but not 100% happy with that...
Kind regards,
Michael
Labviewguru wrote:
> Michael,
> I believe that the reason for the pattern size limit is reasonable
> memory allocation limitations.
> If you are trying to match a pattern that big, it is going to take the
> algorithm a great deal of time (probably on the order of 10s or 100s
> of seconds) to execute.
> My suggestion is to determine if you can do one of two things: A) look
> for a smaller portion of your pattern, or B) break up your pattern
> matching into sections.
> I had a case where I needed to match 8 icons on an LCD display. I
> found that trying to match all 8 at the same time took about 3-4
> seconds, while matching each one seperately took about 1.5 seconds!.
> The reason for this is the way in which the pattern matching algorithm
> works. I am only guessing as to how the algorithm works, but my guess
> does seem to explain the exponential relationship between time pattern
> size and time.
> I am guessing that the pattern matching function works (for
> visualization purposes) by overlapping the pattern with the image
> search area. The most important thing is that the overlap starts by
> overlapping the first pixel of the search area with the last pixel of
> the pattern. For example, imagine a square is your pattern. It is 10
> by 10 pixels. Your search area is 15 by 15 pixels. Pattern matching
> begins by overlaying pixel at 10,10 of the pattern with pixel 1,1 of
> the search area. The algorithm then generates a score based on this
> match. Then, the pattern has pixels 9,10 and 10,10 overlayed with
> pixels 1,1 and 1,2 of the search area. In this case, there will 576
> overlays.
> The formula for determining the number of overlays is as follows:
> p=pixels in pattern (px = pixels in x axis, py = pixels in y axis)
> s=pixels in search area
> o=number of overlays (number of times match scoring is performed)
> o=((px-1)+sx)*((py-1)+sy)
> If you examine the difference between various search patterns and
> pattern sizes, you find that there is an exponential relationship
> between them (200X200 pattern and search area vs. 400X400 yields a
> difference of 4X). This explains why the time difference seems to be
> exponential as well.
> So, given this information, you should probably consider breaking your
> pattern search up, or looking for only a portion of the pattern.
> I hope this helps.
