IMAQ extract (-1074396077), Crop Image
I have a 12 bit CCD camera (Vosskühler). I use the IMAQ vi's, to take the image from the CCD cam the IMAQ Snap.vi. The communication to the camera works fine...
I'd like to crop the "full" image, take a rectangular region of interest of this image. For this purpose I use the IMAQ Extract.vi.
Problem: when I try to crop directly the image which is coming from the camera, the IMAQ Extract.vi generates an error (-1074396077). BUT when I first save the picture on a local drive, reload it again and try to crop it then, then it works properly ! What can be the problem ?
I attached the vi which does not work...
Many thanks for your help
PS: I mean I have a solution with the save, close and reload, but I don't like this !
Cheers, Matthias
Message 1 of 8
(4,798 Views)
Hello MJ77,
can you please delete the image type of the croped image, so no constant is connected?
best regards
Alexander
Message 2 of 8
(4,750 Views)
Hi Alexander,
unfortunately it also does not work ! I have deleted the constant (grayscale u16) from the croped image, but the error still occur.
In my understanding, the "depth" of the pixel (grayscale u8, u16, ...) should not affect a cropping function, but probably I'm wrong.
Do you have another idea ?
Best regards, Matthias
Message 3 of 8
(4,736 Views)
What happens if you don't wire "Image Dst" into the IMAQ Extract VI?
Message 4 of 8
(4,726 Views)
if I don't wire the "Image Name" input of the "IMAQ Extract.VI" then the LabVIEW can't be executed...
if I wire "Image Dst" to the "Image Name" input --> same error...
Did I understand your answer right ?
Other ideas ?
Many thanks. Matthias
Message 5 of 8
(4,719 Views)
Remove the two IMAQ Dispose functions -- they are destroying your images (which are being built just fine, I checked) before you can see them, then when you try to manipulate non-existant images, you get an error.
Message 6 of 8
(4,709 Views)
Accepted by topic author MJ77
Hello MJ77
attached a vi in this you can see what image type came out of the snap function and also the option to load from a file.
I get the same error like you if the image types are not the same.
best regards
Alexander
Message 7 of 8
(4,684 Views)
Thanks at all !
The problem was the data type. Although I defined U16, it was I16 returned from the camera.
LG Matthias
Message 8 of 8
(4,648 Views)
