IMAQ Write Tiff File 2: tiff images with LZW compression?
I need to output images as TIFF files. However, the files are currently too big. I need lossless compresion  - LZW.
I am using LabView 2010, and to save tiff files I am using  IMAQ functions "IMAQ Write to Tiff File 2.vi". Images are quite large - about 16MB (monochrome, 16 bit images). Any of  default compression types, like JPEG, RLE neither ZIP, arent apropriate for me. Does anyone can help me and tell how can I save  files losslessly?
(4,087 Views)
Why are none of the existing options appropriate? Both RLE and ZIP are lossless. ZIP is very similar to LZW.
(4,059 Views)
Try using the Imagemagick utility to re-compress/convert.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,053 Views)
Excellent.  I have also tried to produce image archives without information loss.  I did not achieve more than 5% compression on my archives.
If regular access to the images is a demand, I use the files that "IMAQ Write File" produces.  If I need a backup of lots of image files, I use a usual backup practices.
(4,049 Views)
