IMAQ ImageToArray error 1074396080 while reading 16 bit RGB tiff
I want to get data from a big 16 bit RGB tiff image from my camera (110MB). Image appeare in Image windows, but IMAQ ImageToArray return error 1074396080. If I (at IMAQ Create) select "Grayscale U16" then I get B&W picture and data in "Image Pixels (U16)" indicator without error. With IMAQ Create at RGB64 Image is RGB and you can get 16 bit RGB pixel value under Image window.
I'm using LabView2012 SP1.
(2,897 Views)
I would recommend you to check the File Formats and Image Type Compatibility article. Refer also to the screenshot.
I also found a KB, which has the same topic: Error -1074396080: Invalid Image Type
Hope it helps.
(2,868 Views)
Accepted by topic author Oldi
Problem was, that ImageToArray work only for B&W image. With IMAQ ColorImageToArray VI everything works OK.Smiley Happy
(2,857 Views)
Hi
try setting "Use file path image type" to "Off" in "IMAQ read file 2"
It worked in my case
(2,526 Views)
