08-12-2011 06:35 PM
I've been playing around with the read AVI with buffer example in the Developer Community. It reads all the frames of an AVI into memory and then plays them back at the appropriate frame rate. This works ok with very small AVI files but with anything larger it gets slower and slower until it almost stops loading the AVI. At that point it seems to be loading less than 5 frames per second and is killing my cpu. I have plenty of free RAM during this.
https://decibel.ni.com/content/docs/DOC-8479
This is the case with the play AVI example that comes with Labview too (without a buffer) which just loads and plays one frame at a time. Can someone suggest a way to improve the performance of an AVI player in Labview? My ultimate goal is to read an AVI and detect changes in motion of objects by comparing two frames at a time. These AVIs are going to be at least 5 minutes in duration at a frame rate of 30 fps.
I'm using Labview 2009 with the Vision Developer installed.
08-15-2011 08:00 PM
One thing we could implement is a compression filter that is on the IMAQ AVI Create VI used in conjunction with the IMAQ AVI Get Filter Names VI. Also, what is the RAM available on your computer and what size images are you acquiring and saving to AVI? Thanks!
Kim
08-15-2011 10:25 PM
Kim
Thanks for replying. I'm running labview 2009 on a dual core pentium 2.3 GHz with 4 Gigs of ram. It typically has 2 Gigs free while running the program.
I'm not tryingt write an AVI, I'm trying to read an AVI. The frames are 352 x 240 in size. I've tried several read AVI examples and they all act the same way. They slow down quickly and the hard drive and CPU are really cranking away.
08-16-2011 07:07 PM
I noticed today that when I view an uncompressed video, the read rate is acceptable. The codec decompression seems to really slow things down. The AVIs are normally in xvid. This doesn't happen in media player though.
08-16-2011 07:27 PM
Great to hear that you found something that will read at an acceptable rate. One thing I was going to add was to try to read different size AVI files and see at what point (or read time) the VI starts to slow down, but it seems like the compression on the video increased the buffering of the file.
Kim
