03-17-2010 07:18 AM
Hello people. I need help figuring this problem out.
The program's input is an array of strings. and is meant to do the following:
for each element in the array, checks if the string begins with "$GPRMC"
if this is true, then process the data and spit a value calculated from the string.
else, void (i.e.: not to generate an output value because it spoils the calculations)
i've attached a simplified version of the actual VI. [I'm running on 8.2]
Solved! Go to Solution.
03-17-2010 07:35 AM
03-17-2010 07:38 AM
03-17-2010 07:38 AM - edited 03-17-2010 07:40 AM
thank you guys!
can't see any of them (i have labview 8.2)
maybe an image?
03-17-2010 07:41 AM
03-17-2010 07:43 AM
03-17-2010 07:44 AM
03-17-2010 07:50 AM
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
03-17-2010 07:53 AM
03-17-2010 08:00 AM
yes, instead of modifying the original array you created a new one. and to that new array inserted the elements in the old one that matter.
don't know if this is what you wanted me to see...?
