IDS Ueye_api.dll file cannot be found in system32
I downloaded the Ueye software for Labview and installed it. I had made a VI using the Ueye API  and everything was still fine.
But whenever I open my VI which contains API of Ueye application, I get requests to locate Ueye_api.dll
However when I looked in system 32 folder ( where it was supposed to be), it could not be found.
I tried searching this dll in my C drive, but it was still could not be found.
Now my Ueye API in labview cannot executes and I am stucked, is there anyway to locate this dll or is there any other way around it?
Much help is appreciated
XWX
(10,724 Views)
Accepted by XWX
Reinstalling the driver is the first course of action with such problems. Seems the file has gone somehow from your system. How that could happen would be another interesting question, that nobody else but you can answer.
Rolf Kalbermatter  My Blog
(10,720 Views)
Thankyou for your help.
I installed the driver and it worked. I am new to programming and I appreciate your help!
(10,699 Views)
