01-20-2015 06:23 PM
Beyond the several question that I have heard until now, there is something that makes me nervous, or rather, why there is not an engineer of NI which is able to create a VISA for the TEKTRONIX 420A?
I am saying this because there are several question amde about this oscilloscope that I have but until now I didn0t receive a valida answer. At this point is better that someone of NI produce this code, please!
01-20-2015 07:30 PM
08-31-2015 09:20 PM
08-31-2015 09:45 PM
03-08-2017 11:31 PM
there you go
03-10-2017 12:33 PM - edited 03-10-2017 12:34 PM
Could you tell us what this library means? From a quick glance at the VIs inside it looks like the original old TDK4xx driver from the Instrument driver network. It definitely has no provisions for communicating through a serial port (and uses some very old obsoleted VISA functions too).
While it is principally not a huge amount of work to add serial support to a VISA based driver it's still work that has to be done, and without an instrument to test the result, a pretty frustrating experience too.
Maybe you wanted to upload the fruits of your work in the last 2 years since your first post, so others can profit from your modifications to the driver to support also serial port communication. In that case you grabbed the wrong archive from your computer to upload!
Or this was meant as a dump on this forum, in the hope that someone does the work for you. In that case it was both pretty assuming and rude. Considering that your last post was about 2 years ago, you really should have had enough time to improve your knowledge in LabVIEW and VISA programming, to do this yourself.
03-10-2017 03:56 PM
Serial Support for the Tek is not hard, just remember the following:
Cheers,
mcduff
