04-06-2010 06:05 AM
I have checked out the report writer for saving a front panel screen and it is more than I need. How do I take a number that the user has already entered into the vi and use that for a filename to save a bmp of the front panel to a directory?
Solved! Go to Solution.
04-06-2010 06:12 AM
use the "build path" function in the File I/O Pallete like this
04-06-2010 06:20 AM
I made the path real simple and it worked. I must have had an error in my path structure. Thanks for the input!
04-06-2010 07:02 AM
04-06-2010 07:39 AM
What method are you using? Print to RTF will make a handy Word-ready picture. See attached.
04-06-2010 07:43 AM
Broken Arrow,
I'll give it a try. I have a polar plot with 24 hours worth of an oven temperature on it. I have some string 'labels' on top of it and I just want to save the entire screen to a file. I will try your method. Thanks!
04-06-2010 07:52 AM
Hi Ronster,
there's a method for the VI to get the (whole) frontpanel as picture data to save it with standard picture file functions...
No need to "print" nor to include your string indicators in strange complicated ways...
04-06-2010 07:56 AM
04-06-2010 08:03 AM
04-06-2010 08:05 AM
