I want to update the Numeric Control at the press of a button
Hey,
I am in Labview 7.1
So I have a problem that seems like it should be really simple, but I'm having issues.
I want to increment a Numeric Counter when the user presses a button to record their data, but labview only allows a numeric counter to output data, and not take any in.
I want the variable to be a numeric control so that the user can increment/decrement it themselves if they feel the need to rerun or skip a test number.
Any solutions?
Thank you 🙂
Message 1 of 28
(4,502 Views)
http://zone.ni.com/reference/en-XX/help/lv/71/glang/Property_Node/
That should help you get where you want to go.
Message 2 of 28
(4,485 Views)
Did you try using a shift register?
Message 3 of 28
(4,469 Views)
No, because i needed to change the value of the number control, but there was no input for it
Thanks, I think this is what i needed
Message 4 of 28
(4,448 Views)
I'm not sure how to get the refnum of the Number control. Suggestions?
Message 5 of 28
(4,441 Views)
Go to block diagram, rifght click on Control, then go to create-->reference, this will create reference for you.
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
Message 6 of 28
(4,437 Views)
I figured it out, thank you
(Right click -> Link to -> choose part)
Message 7 of 28
(4,435 Views)
I don't understand how the link to property nodes has anything to do with your question, but to create a reference, you just right-click the control and select "create reference".
Now, to solve your programming issue, you would:
  1. create a simple VI containing an event structure inside a while loop. Add a latch action button and a numeric integer control.
  2. Initialize a shift register with e. g. zero.
  3. Create a local variable (write mode) and wire it to the value in the shift register, right before the event structure.
  4. Create two event cases, one for the "button: value changed", one for the "numeric: value changed".
  5. Wire the shift register across the button case and add a "+1" inside the event.
  6. Place the numeric control in the other case and wire the numeric directly to the output tunnel leading to the shift register.
  7. add trimmings (stop, etc.).
See how far you get... 😄
Message 8 of 28
(4,429 Views)
I've got it working, thanks. This is what I have (Where NumText.Text is the text of the numeric control)
Message 9 of 28
(4,418 Views)
Nooo!!!
Just use a local variable! Don't do a detour over strings and property nodes!
Isn't this supposed to be an integer? I would make the control blue by changing the representation to e.g. I32.
Can you attach your code instead of a picture?
Message 10 of 28
(4,411 Views)
