I want to run my labview application on a remote windows controller
I am able to run a specefic application (finding out the system date and time) built on labview, on an RT controller and able to acquire the required data from it. But I am unable to get the same from a PC with windows os running on it. I am using Ethernet cable. Is there any port problem? or are there any settings which needs to be done.
Sreedhar T
(2,806 Views)
Hi Sreedhar,
Can you ping the Windows PC computer from the computer with the LabVIEW application? Do you know if you are behind a firewall or proxy server? Are you able to open a TCP connection to the Windows PC?
Thanks for the info.
Kileen C.
NI
(2,806 Views)
Hi Kileen,
Thank you very much!!! Our systems are running under a proxy server and thats the reason I am unable to run...
now I have rectified that. Thanks anyway.
Sreedhar
Sreedhar T
(2,806 Views)
Thanks for the update! Best of luck with your application. 🙂
Kileen
(2,806 Views)
