I want to represent a .wav file(which is already recorded) in time domain graphically
hi,
I want to read .wav file (I used read wav ....vi to read but don't know to represent that in  time domain graphically)
and represent in time domain and later in frequency domain and obtain its power spectrum.
Pls someone guide me to get the time domain representation of .wav file data.
Thanks in advance,
Celia
Message 1 of 12
(3,657 Views)
Message 2 of 12
(3,654 Views)
Unclebump
Thanks i got what i wanted.
Now I have to modulate it (using PSK).
help me.
How to use digital waveform graph. I'm seeing multiple plots.
Message 3 of 12
(3,629 Views)
You'll have to show us some code. I'm using 7.0 format.
Message 4 of 12
(3,622 Views)
To use MT modulate PSK.vi i need bit stream how to convert the data i obtained into bitstream
Suggest me.
I've sent the code.
Celia
Message 5 of 12
(3,610 Views)
There are no VIs to convert an analog signal or a wav file to a bit stream for PSK modulation. You would have to do this conversion. Is there a reason you want to use PSK instead of PM?
Jessica Kinnevan
Applications Engineering
Message 6 of 12
(3,578 Views)
yes, I want to do Digital Modulation. PSK being the better option.
Celia
Message 7 of 12
(3,573 Views)
Unclebump
How to send an attachment? I'm not finding any file attachment option here. I replied from my mail & it went to moderator & I did'nt see that mail in the Forums.
Message 8 of 12
(3,563 Views)
i'm just tyring out ignore this
Message Edited by celia on 09-28-2005 01:20 AM
Message 9 of 12
(3,473 Views)
I'm sending the code.
Message Edited by celia on 09-28-2005 02:37 AM
Message Edited by celia on 09-28-2005 02:40 AM
Message 10 of 12
(3,561 Views)
