I want to convert .xls file to .txt file using Labview
Hello sir,
I want to convert the .xls file to .txt file because when i try to open and read the data from the .xls it reads the junk data.
Thanks and regards,
MadhanKumar.P
(3,489 Views)
Open file in Excel, Save as text separated data. 🙂
Else you'll need to use ActiveX commands to do the same thing in Excel.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,484 Views)
Accepted by topic author madhankumarlv@gmail.com
or something like this:
(3,475 Views)
