I want to convert text to a set of coordiantes
Hi everyone,
I have a project to do and i need some help. I'm capturing images with a camera and I read qr codes with it. I got that code (QR code). I'm going to generate QR codes with coordinates, but as a text. Do you have any idea how to convert that text into coordinates and then add it to an array. I have some screenshots with the code bellow.
P.s. I accept any idea of how to get a coordinate from a QR code to my code.
Thank you in advance !
(1,036 Views)
I think we need to see the text you get from the QR-Codes to give you hints how to convert them.
If you have coordinates like
52.514826,13.3771431
you just have to separate them by the comma and then convert the elements to a floating point number with the functions from the string- palette.
Greets, Dave
(1,020 Views)
Hi Andrew,
  • Use ScanFromString to convert text into numeric data.
  • Use BuildArray to "add" to an array (you probably want to build an array instead of adding/summing those values)…
(1,018 Views)
I can type any text so i have no problem making it like that.
 Thank you very much !
(1,013 Views)
I may have some questions regarding this but i'm trying my best to make it work !
(1,012 Views)
