I want to communicate and acquire data using the PC Parallel Port.
How do I to communicate and acquire data from the PC Parallel Port using Labview.
Thank you in advance.
(1,311 Views)
One of the easiest ways is to use the INPORT and OUTPORT VIs. Find what port your parallel port is in and then send data to/receive data from that port. For more information on the port itself, try: http://www.lvr.com/parport.htm#Basics. If you are using NT (I heard some of the other new OS's have the same problem) then you need to download accessHW.zip from the NI site.
Rob
(1,311 Views)
