I want to check if a boolean value is high before it should be, and add 1 to output if it is?
I use a stacked sequence.
1. Random delay time
2. Set value to 1, and check time
3. Wait for click.
4. Check time.
All of the above is inside a for loop.
Second time - first time = reaction time.
I want to check if it has been CLICKED before it is supposed to and add 1 second to the reaction time.
Can anyone explain how to do this?
Thanks.
(2,528 Views)
> 3. Wait for click.
> 4. Check time.
It might work to look at the timestamp on the click event -- if you are
using the event structure. Otherwise, look for the click in parallel
with the rest of the stuff and arrange to get it to the other loop via a
queue or local or notifier.
Greg McKaskle
(2,528 Views)
