I want the wavegraph display 10 grids on x,y axis,how to make it fixed
is there any way to do? wavegraph always display 10 grids on X,Y,and i want the scale on graph is changeable,that is controled.what you tell me isn't practice,any good ways you have?
(2,675 Views)
You can make the scales anything you want. Right click on the graph and you'll see x and y entries. Each of them, by default, have autoscaling turned on. You can use the text tool to manually change each scale's min and max or use a property node to change them programatically. Look at Examples>Fundamentals>Graphs and Charts>Property Nodes.vi
(2,675 Views)
