03-29-2012 08:03 AM
Hello sir,
I want the GUI screen to write and Read the hex file from the atmel atmega microcontroller through the Serial com port . i need the Labview program for the GUI to read and write the hex file from the serial com port.Please help me this is urgent.
Thanks and Regards,
MadhanKumar. P
03-29-2012 08:13 AM - edited 03-29-2012 08:18 AM
You mean to say for programming hex file into microcontroller and reading back the hex file, correct ?
Do you have any programmer for this, otherwise you can use ISP programmer through serial, JTAG or parallel port.
03-29-2012 08:18 AM
yes sir
03-29-2012 08:20 AM
Explain bit more about your project, what hardware & software you have got for it.
03-29-2012 08:30 AM
sir actually In my PCB board the usb port which is connected to atmel atmega 644P microcontroller and the FTDID2xx driver which is connected between USB and Atmega 644P microcontroller and my project is to load the hex file to the atmega 644P microcontroller through the USB port in which FTDI D2xx driver which is connected between the usb and microcontroller. and i need the GUI screen to load the hex file to the microcontroller.
Thanks and Regards,
Madhan
03-29-2012 08:40 AM
sir i want to load the hex file through the USB port only we can't use JTAG or SPI
03-29-2012 08:42 AM
You can use ISP Programmer Pony Programmer ( http://www.lancos.com/ppwin95.html) and try to call it from LabVIEW.
Link for how to use third party software from labview http://zone.ni.com/devzone/cda/tut/p/id/10060
03-29-2012 08:45 AM
ok sir i will try that one.
Thanks and Regards,
Madhan Kumar.P
03-29-2012 09:03 AM
sir In pony programmer we can't read it from the USB port we can read it from SPI itself but i need the GUI to read it from USB port.
03-29-2012 09:11 AM
It means your USB port dont have connection with Atmega SPI programming ports (MOSI,MISO,SCK,RST,GND). You need to make an ISP programmer cable for it, which is shown in link http://www.circuitstoday.com/isp-programmer.
