I recieve the following error when running an executable ("This VI is not Executable. The full development version of Labview is required to fix the errors"
I recieve the following error when trying to build and run a labview executable. I am able to build the executable but when trying to run the executable, a pop up window comes up asking the user to select a dll. (please see screen shot attached). Once the DLL is selected, I get the error that This VI is not Executable. The full development version of Labview is required to fix the errors. (please see screen shot attached). I have also attached a snapshot of the project window.
I have the professional development system
I can run the main VI
all the required DLL's are in the dependencies section of the project window.
I am trying to find the root cause of this error but to no avail. can anyone give me a clue to what i am missing here. Any suggestions on where i should look to find the problem ?
Thanks in advance to all labview users for your help
(1,085 Views)
Are you dynamically calling any VIs from your top level VI?  Also, can you post a screenshot of the block diagram of the main VI?
James K.
(1,053 Views)
