Are you using the driver from the LabVIEW Instrument Driver CD or that you downloaded from
here? If you are, what problems are you having? Are there error codes generated and what are they? Have you verified that the serial cable is correct and the the comm parameters (baud rate, stop bits, etc.) are the same in the program and the instrument?
