I need to use a 3 way switch in labview
So basically a 3 position switch with the needed properties is not possible if I don't want to use slider or dials because in pictRing it will only work in a sequence which is not the output I need.
Message 31 of 41
(1,482 Views)
Hi Neha,
You can also use a PictRing, but you need to place the needed pictures in the needed order. Or you need to switch to the correct picture (using a local variable of the PictRing) as intended…
Like:
IF up THEN
 show image 2
 wait 500ms
 show image 3
ENDIF
IF down THEN
 show image 2
 wait 500ms
 show image 1
ENDIF
Message 32 of 41
(1,476 Views)
Thanks.
Actually I am not able to understand how to do what you have told to do. I am uploading the file could you make the changes or atleast the if else part?
Message 33 of 41
(1,453 Views)
Message 34 of 41
(1,473 Views)
Please do not post a new topic asking us to reply to your "solved" question six hours after your previous post -- be more patient.
Message 35 of 41
(1,416 Views)
Accepted by topic author Neha987
Something like this?
Three are many other ways to implement that logic too.
Good luck.
Certified LabVIEW Developer (CLD)
There are two ways to tell somebody thanks: Kudos and Marked Solutions
Message 36 of 41
(1,374 Views)
you could exploit the Frontpanels multi-layers to create something like an HTML image map
using several Boolean indicators in a Radio Button Control set to transparent.
Message 37 of 41
(1,362 Views)
Could you please upload that file??
Message 38 of 41
(1,328 Views)
don't write me private messages, calm down and reproduce it yourself.
you will have to maintenance this piece of code
if it is so urgent, get rid of your original idea and do one of the better, possibly more user-friendly alternatives other have suggest to you in this thread.
here's the snippet for Message 37
as you can see, this  3 way switch will only "work" if the .vi is executed - because I cheated and turned the 3waycontrol in an indicator, which is triggered by a modified radio button control.
if you want to use, this snippet, it will "break" the order of frontpanel layers
so I attach the .vi
I suppose, you will have to put some more effort into this, before you can use this in a practical application.
Message 39 of 41
(1,309 Views)
If you cannot make the code for yourself from the two images that I posted, then perhaps you need to hire someone to do the work for you. I assume since it is so urgent, you would not have time to learn LabVIEW yourself. There are some free tutorials on the home page of the forums that you should investigate.
Message 40 of 41
(1,275 Views)
